oil level wont effect it.
They run best with the AFM. If running correctly disconnecting the AFM will decrease performance. Often when there is issue with the engine disconnecting the AFM will overcome the issue. And you do have the wrong AFM. You need a plastic body one as you have a 20 series engine.
