MtyMseHarmer
I recently got my 1uzfe swapped into an 82 Supra running. However, it won't rev last 4K RPM. I am guessing that means it is in limp mode. My problem is I can't check for any codes because the check engine light does come on at any point.
The current engine/wiring/ECU setup is- Engine is from a 95. Harness was originally a 95 but converted to run a 94 ECU.
Any help on where to start looking for why the CEL does comes on so I can check codes is appreciated.
Thanks!
Thanks!
