phillipguru
long story short me and a buddy cleaned the maf, put it in crap a/f cleaned it again, better a/f drove it around ran fine for a day, next day i took it out cleaned it realllly good put it in, reved to 5k and it was normal except for a couple a/f drops at 3k under hard acceleration. next day i checked the diag port and came up with error 31 right, map circuit error, so i reset the ecu and called it a night
today i get up at 530am and drive to work, no problems, no check light, drive home, no problems, no bucking from bad a/f mix, drive it to walmart and back a few times to buy gear oil and return it to get the proper grade. no problems... i start to get worried something else is messed up or maybe even working like it should, I check the diag port and the check light just flashes constantly i counted over 40 times no breaks no stops no pauses.
does the constant blink meen everything is ok, i cannot find any info for that code.... but the car is running fine. I wonder if it just took some time and air passing through the maf for it to be happy again
