Hey guys, i need two unporteed heads, so i can cut up one and try welding up the side of the inlet ports so you can port the heads alot more.
I will measure the wall thickness before grinding through to the water jackets.
again these heads can be stuffed and un useable all pics of the work will be posted up on this forum.
Thanks Kiwi for the other head i was given as i'll test that one first with the new extra large intake ports.
