Need ideas for fuel pump connection
morris
I hope somebody can give me some ideas. I have an intank walbro setup in my car. A fitting in the tank seems to be leaking and as such my fuel pressure varys and then of course my AFR varies. Of course this is bad for a FI car.
Can someone give me some ideas on how to connect it to the -6 and fuel line.
Right now I have a -6 an bulkhead connector sitting on the top of the tank. Inside the tank I have a -6 female hose end connected to the male bulkhead fitting. on the female -6 hose end I have a piece of 5/16 hose pushed on and then a hose clamp on that. The other end of the 5/16 hose goes to the walbro with another hose clamp.
My guess is that the end onthe walbro is leaking 5/16 is really a bit two big I think but the next smaller size will not fit over the -6 AN hose end connected to the bulkhead adapter.
BAsically what is the best way to attach the walbro pump to the fuel line.
Thanks
Fix the leak or fit a surge tank and fit another 044 Bosch or Walbro external with filter after ext pump...With relay switched off in tank wires.. Then feed external direct from battery...
