Need help I have my datsun together and running. I am running a wolf 3d running of the passenger side cam angle sensor. The thing runs sweet when it is warm have not sorted cold start yet. But I have a major problem it will not rev past 5000 rpm it has the most horrid rev limit you have ever seen. This contributed to the tail shaft letting go I suspect it is that violent. It will bounce between 5 and 4 ½ 000 in the blink of an eye. The wolf does not have the limiter set soft and hard limiter are not active I believe. I have had this problem for quite some time two tuners have looked at it. I really need something. I just can’t figure it out.
other than that she sounds pretty swwet and is not to shabby.
