problem with the 2uz is that its a drive by wire design. Best best is to find one at a junk yard used. Since the 3uz and late 1uz has the same intake manifold and TB, they will most likely be a direct swap. You can test the TB by feeding voltage to the DBW motor and see if it steps like it should.
