I would not want to disclose this member's engine but you can see the pictures below. Its just purely nasty. He put in the waterpump initially and it leak then he add extra silicon sealer. He did fix the leak but he also created another problem. However, he is very lucky no overheating issue yet.
Picture #1: Red silicon squezing out from the waterpump
Picture #2: More detail on the over silicon sealer
Picture #3: Picture of execessive sealer inside of the water pump
Picture #4: More detail on the sealer inside of the waterpump
Picture #5: More detail on the sealer inside of the waterpump
Picture #6: Water pump gasket
Why we shouldn't use silicon sealer? If you have experience with it then its ok. However, more diy are not experienced therefore I recommend getting a water gasket for your repairs.
When you buy a water pump from a local Lexus dealer you don't get the waterpump gasket. Most Lexus tech won't know this gasket exist. I have been to many dealers and most part tech guys are not that knowledgeable. I highly recommend this gasket to save u headaches and thousands of dollars.
When those silicon sealers got loose and block your water passages and this will lead to overheating. I had this incident to my engine and overheated and damaged my heads. I got a connection with my buddy on those gaskets and they are $10 each plus shipping.
