RotaSpinna
After much debate, the shop I am working with on my new SC400 project and I have decided NOT to swap in a 2JZ!
I have a stock '94 SC400 that I plan on leaving NA, 2UZFE bottom(with valvesprings and arp/acl goodies), and engine management. After doing a bit of research on the v-eight and this website, I still haven't come up with a good answer to my questions...
I understand the 2UZ pistons with 1UZ heads is a problem due to combustion chamber differences, but will swapping out the crank alone fix this problem? If that alone will help, what will the final compression numbers be? I also thought I read that you might be able to get away with just a thicker Cometic head gasket. If THAT is true, what would the final compression numbers be?
As stated I'd like to keep the engine NA, so factory 1UZ compression or higher is needed. The finished project needs to be done by March, so I'd like to stay on a tight budget and put more labor time into it instead. So no custom piston suggestions please![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Thanks for the help and suggestions in advance!
Andrew
Andrew
