Hey Guys,
Thought I'd contribute a few photo's of a set of Headers that I'm having built at the moment by my key fabricator at my workshop.
Not a huge amount of thought went into tuned length or collector merging. I figured that anything had to be better than the standard UZ131 Log style that I've had on my hilux for the past 4 years.
I used the exhaust gaskets to draw up the flanges and then cut them out in our inhouse CNC plasma cutter. Primary pipes are 41mm in Dia (1 5/8") and are a simple 4 into 1 design. It was originally going to be a tri - Y design, but space constraints and allowing for the engine torquing over meant that a 4 onto 1 design made sense.
Just tacked together for the moment. The tacks will be cleaned up and then TIG welded together. I'll shoot them out for Ceramic Coating when done. All pumbing is exhaust grade steel.
I have an M90 kit ready to go on, so hopefully these will work well and I'll be able to exploit the forced induction gains without exhaust restriction.
Promise I'll add more photos as they progress.
