Forgot to ask, does anyone have or know of a belt part number for 1uz not running power steering? ive kept everything else on it , alternator and A/C and hydraulic fan pump pulley. thanks
Nice clean motor you got yourself there!
Ta22? Dear god man! Now that I want to see!
I just cut the orginal belt an then routed it how I wanted it and
then cut the excess were they meet, to give me a rough idea on a
belt measure. Piece of string tied would work as rough guide.
If you can't find something even close, you could change the
position of the alt with the P/S with a custom stud and spacer
and bracket to obtain different lengths...may be even go to the
lengths as to experiment with different sized pulley diameters.
When I did Hilux I had similar belt size issue, but I didn't run P/S or A/C
I know this is all types of wrong, but I was given only 3
belt sizes to choice from that were even close out of the
entire Bosch and Gates ranges. They were 6PK1100 and
6PK1085, which were way too big, and
6PK1040 which fitted,
but only if I ran it like this, using the Alt as the tensioner
and Oil pump gutted as a idler. It works well. No noise from
any bearings as yet.
