spf_lexus
Just gave my 1uz a valve job and once finished my driver side has a "wetness"
at the front of the block (the only head stud available w/o removing anything). And it's this front corner thats the problem. I drove it 1200 miles from california to colorado and it managed to stop w/ a can of coolant leak stop but now i can see the wetness again. My car has not been going through coolant lately and i know at it's worse it only appears "wet". I can wipe the wetness away at idle and then the wetness at the seal re-appears but won't run/drip.
I used MLS gaskets and torqued as per OEM order and 3-stepped the torquing. I finished at 45 ft/lb using a brand new torque wrench.
I also had the heads machined and they never were scratched and the block was cleaned w/ a wire wheel that wont score the metal.
My issue is that it's all hunky-dory right now and i am waiting on a fuel pump before the 7psi of boost gets bolted back on. I don't know how much of an impact doing this will have. I have heard these steel gaskets are more "temperamental" than oem. Should I go back and re-torque everything maybe 5-10ft/lb higher to ensure an even seat?? I know my ARP head studs are rated to higher than oem tolerances so can this be done safely?
please add to this if you have run into similar problems, Lexus tech said for 1uz it should be ONLY oem and that steel will give problems.
My gut is telling em that since i have stronger than oem gaskets + head studs whats the harm in torquing higher? Also got mixed feelings about the tightness, and that 45ft/lb is way too low but i heard that over 45 is too high, what gives? I was told by an engine builder that 75ft/lb is what he'd do. I feel like torquing higher and see how it turn's out since i don't have to rip the heads out again. I need some real brains on this one lol.
