I spent nearly all day last Tuesday working on my LS 400,it took me most of the morning getting the cat off the car,all the bolts were rusty so i had to cut them all off,a 4inch grinner was to big and bulky to get to the bolts so i used a dremel..a right nasty job that was...so the cat was removed...
The bolts holding the emmisions pipe on the downpipe of the exhaust came undone easy,so did the bolts holding the end of the pipe going back into the inlet manifold,the single bolt supporting the pipe half way down the emmisions pipe came undone easy....Then i spent over a hour trying to get the emmisions pipe out from behind the engine...i tryed removing the pipe from the top and tryed removing the dam pipe from underneath the car...
I ended up breaking the pipe into 2 pieces,was still a pig of a job.
I then got a friend to cut the flanges off each end of the emmisions pipe and fill the holes in on the flanges...i put one stop end where the emmisions pipe bolted to the exhaust and the other where the emmisions pipe went to the inlet manifold....so job done i thought...
Now since driving the car for nearly a week,what ive noticed...
Plus points
Yea the exhaust blowing sound has gone...so its quieter to drive.
The response of the Throttle seems better
Bad points...
Its been warm over here for a few weeks now so its not been that cold over night,my point...the cars taking a age to warm up from cold now with no emmisions pipe feeding the inlet manifold with hot air...so come the winter whos know how long its going to take to warm up!!
I also notice that the cars is "pinking" around 1800rpm,which i didnt notice before,the emmisions pipe wasnt sounding that loud before i removed it so im sure i would have heard the "pinky"
So it seems as though the fueling has changed now that i have blocked off each end of the pipes.
As to my other posts,i can see now theres no rubber section in the emmisions pipe,just a flexy effort to allow the pipe to flex abit,its on the flexy bit where the pipe was blowing...
Any ideas guys
Im thinking of getting another emmisions pipe because the engine is using soooo much more petrol now...i was getting good mpg....now its down to around 13mpg...with the same driving style...
Its mainly shortish trips i do so the engine is always warming back up after standing for a while.
Sorry to write such a long post...
Plus points
Bad points...
Any ideas guys
