Hello everyone, it's been a while:sorry: and have been cruising the forums from time to time.. Some may know that I have progressed from my 4x4 build to a much better 4x4.. anyway..
Last week after sitting for a couple months.. ( not a daily driver) I took my truck out for a thrash as we had a trip over the coast and it was just a drive to make sure things are good.. anway.. on my way home.. no power, sounded like ***** blah blah.. Now the fun..
checked and replaced plugs, swapped coils and ignitors, checked fueling and was all good..
Now the really fun bit.. checked timing and I was about 6 teeth out from the cams on the markers on the body of the engine I know I have a gen 1 so no problems but I have a bad miss now after aligning things correctly and for the life of me I cant work it out.. caps and rotors?
Bit of history,
sc's with a m90 running 9 psi pulley, big injectors etc.. link gen 1 ecu and havnt had any problems until last week.. any one got any ideas ? other then replacing caps and rotors.. which is on the cards , ecu runs a very simple setup and have checked cam and crank sensors and are just below 11k ohms.. is this a problem? also cam belt, its in great condition but should I replace it ? seeing as I have a miss.. miss is in a couple spots.. around 1500 rpm and 4500 rpm give or take a bit.. Im also logging sync errors so wondering if cam and crank sensors are buggered.. Had a good run so far and most likely needs a birthday.. so any advice would be great
cheers K
Bit of history,
cheers K
