Instead of help, I thought I would offer some.
I put the 1uz/A340 from a 92 SC400 into my 95 Nissan pickup. Ran it this way for about 2 months, and the stock ECU started running funny. Ground issues, dropping one coil, no read out on CEL. Things just started piling up. With future upgrades planned, I decided to go with a Megasquirt 3/3.57/MS3X. I cheated and bought the pre-assembled kit, both wire looms, and a wideband (MTX-L). Also bought the full version of TunerStudio - recommend you do that as well.
Took about 13 hours for the install. No great hurry, and lots of interruptions.
Just got it running/driving right, so I will have some improvements to add shortly. Still need to add IAC, trans control (Using 1UZ ecu to handle).
Running fully sequential fuel, and stock ignition for now.
When I bought the pre-assembled unit, the j7 jumper was bridging 1-2 on the MS3X board. It should not bridge at all. Going into the "diagnostics" then "composite logger", you can view the signals from the cam and crank sensor (using the cam sensor closes to cyl #1).
My crank signal was great from the start, but the cam was not.
The red on bottom shows a loss of sync.
This is another view of the bad cam signal
Idle was fine, but as soon as the rpms increased passed 1500, things went funny, I lost sync, and the controller injected fuel for 9000rpm. Simple fix for me. I adjusted the hysteresis on the MS3X board (cam), using the adjustable pot. From fully out, I had to go in approx 6 full turns. You can watch the improvement on the "composite logger" as you turn. Get just enough and stop.
Cleaned up cam signal
Close up of the signals. You can see the 12 crank pulses x2 vs 1 cam signal
Those two items were the only real hiccups I incurred. Got it warmed up, started auto tune, and it's running smoothly right now. Sure there is more cold start stuff to handle, and getting idle control working. Compared to my last system, MS3 was a breeze.
If you have any questions for your setup, let me know, I'll try to help.
