hey,
daft question time
i'm fitting a 1uz to a LJ70 land cruiser and want to use megasquirt, i figure that i want the basic system as its just for an off roader so ms1 with edis wasted spark , and i think i need a trigger wheel which i can make from a universal one, crank sensor, coolant sensor, air temp sensor, and an o2 sensor
questions are do i run 1 or 2 o2 sensors?
i take it the missing tooth goes at TDC piston 1 on the bang stroke?
do i need a throttle position sensor?
I read that GM sensors are compatable with MS, so if i go down the breakers and whip the temperature sensors, o2 sensors and crank sensor from a petrol vauxhall will they work?
when i get all the wires to the right place, connect the battery, stick the key in and turn it.... will it fire? or do i need to program data into the box of tricks?
sorry if this seems like i'm not trying to look for the information myself.
cheers much,
Ali
daft question time
![Eek! :o :o](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
cheers much,
Ali
