V VH 1UZ-FE New Member Oct 29, 2004 #1 Does anyone know where I can put a mechanical water teperature probe in the block? Thanks
Red Supra New Member Oct 30, 2004 #2 Why not in one of the cylinder heads or lower intake. Cylinder head temp is more cruicial to engine performance than engine block temp.
Lextreme II Active Member Oct 30, 2004 #3 You can put in anywhere along the radiator hoses. My favorite place is the run a T of one of Throttle Body Coolant lines. This method is the easiest, but might not give you the true engine temperature.
Zuffen Super Moderator Staff member Oct 30, 2004 #4 Why not tap the plug on the front water bridge to suit your sender. You can get adaptor from an Hydraulic specialist. I got mine from Pirtek.
