Warm Pudgy
For the last few months I've been taking my 92 sc400 to mechanic after mechanic, after mechanic, with no one able to figure out whats wrong with my car.
The current mechanic says its the IAC causing all the problems
I do not think the IAC will cause the cause the engine to hesitate under load.
IAC should not cause this to happen:
http://yfrog.com/n6vid20100909163306z
http://yfrog.com/mqvid20100909164022z
After this post I have the IAC wired correctly, and it idles just fine.
I've replaced ALL sensors related to air/fuel mixture
Fuel pump is fine, fuel pressure is fine (new filter as well)
There are NO CODES, NO CHECK ENGINE LIGHT
I've eliminated every possible vacuum leak.
Fuel injectors are clean and working properly.
Plugs and cables are new.
I'm at a complete loss as to what to do next. I'm temped to commit insurance fraud and just burn the damn thing or drive it over a cliff.
