Gene FJ20DEBT
Hey all.
Just a quick question.. Master warning light (the circle with the exclamation mark in it)
For some reason when the cars under load it comes on, then when I back off it goes out.. this happens when I take off (doesn’t even need to be a heavy tack off) and it will come on.. once up to speed and coasting it goes out.. then if I give it a boot full it will come on till I get of the gas, then it goes off again… I can free rev the engine in neutral and the light doesn’t come on. Car seems to be running fine and normal..
I remember this was happening when I had low oil one time, but it happen along side the oil light coming on at the same times… this time its just the warning light, not oil light..
Engine oil is correct so im assuming its not that.
So basically that warning light is coming on with no other lights to indicate where the issue is?????
