Master Engine Gasket Set
RS5773
Hello,
First, sorry if Ive missed this while searching for the information. I have a 94 1UZ motor that I need a quality master engine gasket set for. In the past I’ve used Aisin And had great luck but I have not found the part number available. I also found Nippon Reinz available but as far as quality is the big question for me. I have found Felpro as well.
I will be using separate cometic head gaskets so it’s just the other gaskets are what I’m chasing.
What engine master kits have you had luck with?
Thank you in advance.
Richard
Hey Richard,
What did you end up doing for a master gasket set? Did you find a Felpro set?
If you did, what is the part number and where did you buy the set from? I’m in Perth.
has anyone had experience with the sets available out of China? I know some of the gear coming from there is below average, but some of it is also very good. Any info from someone who has used them would be great.
cheers,
Shuey
