Parts M122 Supercharger with parts to fit a 1UZFE non VVTI
ivan129
BlownZX
For sale I have an Eaton M122 Supercharger with parts to fit a Lexus / Toyota 1UZFE engine minus the manifold.
This Supercharger could be fitted to any other engine if adaptored. Asking $3150.
Parts available:-
1 x Eaton M122 Supercharger as shown
• Ported inlet and outlet to improve flow
• Fitted with a 1:1 rising rate fuel regulator and fuel pressure gauge
• 6 rib 75mm diameter drive pulley
• Bypass fitted
1 x Ford twin 57mm throttle body with adaptor manifold that fits the Supercharger. Idle valve and throttle cable mount bracket fitted.
1 x M122 Supercharger base plate to fit a Bullet Supercharger manifold for a non VVTI 1UZFE
1 x 16mm spacer plate that fits below the base plate (between base plate and manifold)
All Bolts and screws to mount
8 x 650cc Sard fuel injectors that will suit this setup. (high impedance, denso connector, 11mm top feed) fits std fuel rail.
Parts you will need if fitting to a Non-VVTI 1UZFE. TPS and inlet manifold.
More high definition pictures available. Site won't allow me to up load them.
Gumtree add:
- Supercharger, Eaton M122 with parts to fit a Toyota / Lexus 1UZFE | Engine, Engine Parts & Transmission | Gumtree Australia Casey Area - Cranbourne North | 1310323187
Free pickup from Cranbourne Vic. or can be packed and shipped at buyer’s cost.
