Thanks all that's useful information.
http://euler9.tripod.com/bolt-database/22.html
I had a similar problem, if you have an auto tran and swap to a manual, hang onto the 6 little bolts as they are hard to get and other members may run into the difficulty I did. The Flex plate to Torque Converter bolts are M9 x 12mm (approx) to stop you putting the wrong bolts in there and are tricky to source. It's interesting that the article on bolts you linked to Doug said 'avoid' using this size as they are not very common.
I did get some btw, thanks to Neil at Rush imports - cheers.
