Hey guys, i have an annoying problem.
Its a 91 LS400 240000km's. Problem is at idle once running for a while its has a slight miss. At hi (4000rpm +) under load it misses/splutters badly when you nail it from about 2000 rpm.
So far I have replaced the plugs, fuel filter & checked all the leads, also fuel pressure regulator. I've checked the intake and all ok.
In Park or Neutral you can take it up & down the rev range no problem. It's only when its under load.
A good mate that works on them has suggested either the fuel pump or a coil is starting to break down.
Any ideas. I can still drive the car if I take it easy at the moment.
