My LS400 transmission engage hardly ( at 500 RPM only ) when shift to D after little delay ! also if I move the shifter to 2 I will get 3rd and if I shift to 1 I will get 2nd ??? except that it is working properly . what is the problem ?
The oil level is ok . no leak . separate radiator installed !
Also if I press the pedal to the floor while I am going at 20 KM/h only it will not go to the 1st gear . Only it happen at 10 Km/h or less !! it is regular for lexuse transmission ?? any suggestion ??
