R redback New Member Oct 26, 2009 #1 Hey guys, Had a bit of a quick search on the forum. im either blind or just cant read because im sure this would of been asked before. Is there a company that makes extractors for the LS400 1990??? ive been search all over the place. cheers
Lextreme II Active Member Oct 26, 2009 #2 Moving to exhaust section.... however, I dont think there are any that will bolt on.
R redback New Member Oct 27, 2009 #3 if you could make them and distribute them at a cheap price there would be a decent market...
J JBrady Active Member Oct 27, 2009 #4 The S&S will bolt on and fit the car chassis but will require at least a custom Y pipe to connect. The Rush headers for the SC400/Soarer may fit with the same above needs.
J JBrady Active Member Oct 28, 2009 #6 Lextreme said: John, Anyone ever try the SS headers on a LS? Click to expand... David, Several people. To keep cats you will need to mod the headers and or the cats. Here is a guy that modded the headers on his 95 http://www.clublexus.com/forums/ls4...nd-exhaust-installed-pictorial-and-video.html I will do something similar to make them fit with the stock cats and stock Y pipe.
R redback New Member Oct 28, 2009 #8 Where can i get these... anyone got a Link? EDIT: Found it.... i was just slack. Last edited: Oct 28, 2009
spf_lexus Active Member Oct 30, 2009 #9 Rush headers will not fit early LS. This came from Neil @ Rush imports. S&S is best bet.
A adarmo Member Jan 15, 2010 #10 When searching try using 'Headers' and 'manifolds' too, might reveal more results.
