Hi,
I'm working on a project and looking for a 4 piston calliper to use.
I'd like to know how strong the 4 piston LS400 calipers are and how there performance is.
Secondly i already looked up the depth of the caliper to the rotor (67mm).
What i would like to check would be what is the height of the caliper (from disc)
4 piston calipers run a 28mm thick disc correct?
What kind of rear caliper is used on the LS400? (291mm discs right?)
I would presume a single piston floating design.
