LS1 Swapping
i can supply u a wiring loom all wired up and all u have to do is connect afew wires to the car
another thing u will have to do is fit an oil pressure sensor and a temp gauge sensor
this is cause the ls1 sensors work thru serial data lines to the bcm and to the dash
so u have to fit the oil pressure sensor and the temp gauge sensor from the ae86 somewhere to the ls1 engine
i can supply the stuff for fitting sensors aswell
another thing is the ls1 6 speed gbox is pretty large so u will need a tunnel made up
