I have a front sump 2UZ-FE and I need a rear sump oil pan. Looking to trade the upper and lower pan, baffle, pick-up pipe and dip stick (if necessary) for a complete rear sump set-up.
Yes it will, the oil pan dimensions bolt/pattern are the same, the upper pan is aluminum the same as the 1UZ as well.
Tried to PM you, thought that perhaps you had to "friend" someone on this forum, turns out that you probably don't have PM enabled in your options. In any case if you are interested in trading parts, let me know. We're close enough, I could drive down with my parts and meet you, which would let you compare parts if you have any doubt as to if they'd fit.
