ivan129
BlownZX
Hi Everyone, Throwing this out there for information and ideas.
I'm looking for a drive by wire system that can simulate a standard cable system that just provides a TPS signal to the ECU.
The system needs to read the tps (1 or 2 outputs) from a DBW accelerator pedal, operate the actuator (mechanism in the drive by wire) throttle body and put out a TPS signal (0 - 5V) for an older ECU that doesn't support drive by wire.
The system should have a calibration process to learn and map the pedal movement and travel to an openning profile for the butterfly.
Mega Squirt had such a system however they seem to have been bought out or closed down.
Please respond if you have any info.
Thanks.
PS... Yes, I'm googling...
Thanks.
