Import Performance Transmission - first choice -
http://www.importperformancetrans.com/toyotaauto.shtml
TOYOTA / LEXUS PERFORMANCE AUTOMATICS
ES300, GS300, GS400, GS430, IS300, LS 400, LS430, LX450, LX470, RX300, RX330, SC300, SC400, SUPRA, CAMRY, 4 RUNNER, CELICA, LAND CRUISER, TACOMA, T100, RAV 4, TUNDRA, JEEP AW4, ISUZU 30-40LE
REAR WHEEL DRIVE / 4 WHEEL DRIVE
* Valve body is custom calibrated to provide the ultimate in clutch application power and clamping force (The modifications performed by us are a proprietary design and are unavailable elsewhere)
* Virtually indestructible Raybestos Blue Plates are installed in all shifting clutches
* *NEW FEATURE* We have now developed the industry's only 6 friction disk C-2 clutch pack for a 50% increase in third gear holding capacity.
* New one way clutches (sprags) are installed in all locations
* Planetary splines are heat treated to prevent stripping
* Metalax treatment is applied to input shaft to eliminate stress related failure
* Sun shell is heat treated to prevent spline stripping
* New design high flow solenoid assemblies are installed
* Lube system is redesigned to provide increased flow and cooler operation
* Performance pressure regulator boost valve is installed to prevent sluggish line pressure rise and to increase clutch holding ability.
NOTE: This unit is the strongest configuration that can be achieved with this Toyota transmission. However, if you are running much faster than 9.99 we recommend the installation of a domestic three speed or Powerglide transmission. These units also enable you to enjoy the many benefits of a Trans Brake and 8", 9", or 10" torque converter. See our specialty RWD section or call us for details.
http://www.sae.org/technical/papers/2004-01-0650
Abstract:
Toyota Motor Corporation has recently developed a new six-speed automatic transmission (A761E) for Front Engine Rear Wheel Drive (FR) vehicles. Following the general trend of increased shift stages and a wider range of gear ratios, this six-speed automatic transmission has been developed with attention paid to the gear steps and a wider range of gear ratios. By balanced selection of close-ratio gears in a wider range, the change greatly improves the power performance and fuel economy of the vehicle. To further improve fuel economy we have adopted new technologies such as low-viscosity ATF, neutral control, and deceleration control by extending the fuel cut range (reset speed). We have also adopted a flat-shaped torque converter, small solenoids, an aluminum oil pump cover, etc., to realize the lightest six-speed automatic transmission in the world. This automatic transmission is low cost due to the adoption of the same gear train as the previously developed five-speed automatic transmission (A750E).
A761E
6 Speed Automatic Transmission
Applications:
* 2006-2007 IS350
* 2004-2006 LS430
* 2006-2007 GS430
* 2006-2007 SC430
Gear Ratios: 1st 3.296 2nd 1.958 3rd 1.348 4th 1.000 5th 0.725 6th 0.582 Rev 2.951
