1st of all is the LCD clock (the digital one in climate control unit) suppposed to be off when key is out?
Question is that when I remove the key from the ignition the clock is still running, does anyone know what the problem is? The only way to turn it off is to disconnect the battery.
I tried removing the fuse (7.5A panel one) but the clock is still on (it's running because I can adjust the time by pressing those little buttons) even when the key is out from the ignition.
shed some lights pls
Thanks in advance
Car is a 93 LS
Thanks in advance
Car is a 93 LS
