hi-lex
just to let you all know these DO work, I have used 2 units on the xf falcon I have just finished, I have used 1 for the speedo to convert from toyota 20 pulse sender down to 7 needed for the ford and another using the same sender pulse down to 4 pulse needed for the auto to shift which also allows shift point adjustment, they are avail from jaycar electronics for about $49, I will post up which selectable links are needed later as I left my notes at work, I tested it on a CRO b4 I installed it an pre set it roughly
