ozvenom
Well guys it been about 18 months since i bought my first t70 and finally we have some dyno results that are real and some thing i can belive.
The car is a friends venom cobra with a 1uz backed by a tremec 3550 5speed and a r32 gtr skyline rear end. it has autronic sm2 ecu and has made 225 Hp at the wheels natrally asperated.
i mounted the turbo in front of the negine with 4into1 1 3/4 headers leading into 2 1/2 " y pipe which has a divider where the 2 sides merge giving a true splitpulse to the turbo. a 3" dump pipe which splits into 2 2 1/2 " pipes which then joint the original 21/2 exhaust system.
The engine is stock except bigger injectors. intercooler is a tube and fin measureing 600 x 300 x 65. not huge but big enough.
the waste gate has a 7psi spring so it makes .5 bar boost. a boost contoler will be fitted this week so bigger boost levels are coming.
So what did it make 322 rwhp and 1566ft/lbs of torque at the wheels.
it also had 5psi by 2000rpm so it get going early with the split pulse system.
all in all i am very happy with the way the turbo perfomed . only thing now is its durability ,at 7psi should not be a problem.
Regards oz.
Regards oz.
