Hi Guys, I'm max, this is my first post in this great forum that i've been reading for a few months.
I live all the way down in Chile in a small touristic town called "San pedro de Atacama" in the driest desert of this planet.
I've been around Toyotas since I can remember, mainly Hiluxes 4Runners and Land Cruisers. Since this year i've been involved with the 1UZ's thanks to a friend that made look into swapping one instead of my tired and thirsty 22R.
So this is my first question:
I've got a JDM 1st gen 92 to 94 1UZ-FE that it's not running, it all seems to point at the ecu, which doesn't turn the check engine light on, but it turns itself on when when I put +12 in the MREL pin. Did all the wiring myself and the ecu it's the one with the Huge 80 and 40 pin connector.
I'm guessing the ECU it's toasted or something, and I just want to get it running, now the question: Would a USDM ecu that I can buy Off Ebay work on this engine without throwing codes?
As the ECU Number parts are not the same.
As this engine and loom seems to have only 2 o2 sensors with only 1 wire each. It has the cold start injector also.
I read the post about the capacitors, they seem hmmm not so great. Could this be the cause?
It came out of a SC400.
Any ideas?
Cheers, I'm all ears.
Any ideas?
