well i was not going to bother, not at 8psi, but read the theory books abit and since a will no dought want more boost once i have uprated my rods an going ahead with ic..
now have looked at many on here,and all seem to be using air to water, ok i see that will be good at slow speeds, but most (not all) seem to be using really small units cramed in manifold..
that seems to me to be not how to do it..looking at them i cant see how they will cool the charge by any significent amount, for a start the outlet of the sc only blows across half of it, and then alot seem to be using oil coolers or even heater matrix's..it ain't gonna work, even ones using "proper" charge coolers i cant see working at all well due to the limited size..then there is the distibution evenly to each cylinder...no not for me..
so i am going for now use air to air..i spent 7 hours today just looking at my manifold and trying to work out how to do it..(its only got 40mm internal height)..i got it in the end..
internal box covering outlet of sc flowing it to rear of top manifold cover and out just behind sc though top plate, thus keeping the manifold gas tight..the return will go in at the front of manifold (on the side)..the charge then forced around the internal box over the lower manifold outlets..
yes this does require some neat welding and alittle baffling, but no real dramers there i hope..
this way i can also if i wish make a large proper air to water charge cooler if i wish..
why no one charge cool sc externally to manifold??is there a problem with this?
also..whats min dia of piping to use to connect to intercooler..2inch would be good (read very handy and make things easy), but i expect may be too small...what do you turbo boys use in intercoler piping dia?
thanks
thanks
