Instrument cluster needed?
JKav
I'm in the process of swapping a 1UZ from a 1996 SC400 into a Subaru (w/ a manual gearbox).
Is the original SC400 instrument cluster needed in order for this engine run and run properly? Nothing I see in the wiring diagrams (or in searches here) indicates that the cluster is required, but electrons are unruly little bastards so I want to be certain.
Appreciate any insight you can share.
Background - ECU label reads:
Toyota 89661-24453
175000-9270 12V
IUZ-FE 52
Engine label reads 1uz-Z83
Toyota 89661-24453
175000-9270 12V
IUZ-FE 52
Cluster is not needed. If you want your Subaru cluster to work, just feed it the correct signals it is expecting.
