info on setting up tb and tps please
zen
have idle issue..
dies when on over run,idle drops too low before iacv can ramp it up and stalls..
not iacv,air leaks etc..
so as i know tb and tps have been played with before i got them i would like to set them up as per toyota intended...have no info though..
engine is 1995 2nd gen,skinny rods type..
for a cure (untill can setup)i have run a bypass pipe from before tb to after tb with a small valve in,this allows me to set base idle to what ever i like (i like 750rpm)..this cures the prolem as now idle never drops below...but its a bodge..
anyone have toyota info on setting up please..(ie tb adjusting screw and tps position..tb screw more important!)
