Bhogg
Hi All
Please Admin if this post is better located to another area please do.
I’ve currently got a Toyota 4Runner with an imported 89 model 1uz engine in it.
It’s an 89 model engine so exactly how long the engine has sat around for is anyone’s guess,.
My problem is I’ve got a bad over heating issue!, I’ve Replaced the water pump, thermostat and radiator cap and had the radiator tanks taken off and it all cleaned out and it’s got a 16 inch thermo fan behind it and it’s still over heating it’s been tested for a possible blown head gasket and that came back clear.
Even in winter months under load it’ll overheat and on a 30 degree day if I try to drive on 110kmph on the highway it’ll overheat.
So at the current moment I’m leaning towards something either blocking water flow in the heads/ engine due to it possibly sitting for a long duration?.
So I’m really wanting some help and or ideas what might be causing it as I’m at a real loss now!!.
So please guys / girls I’d really appreciate any help!!
Cheers All
Cheers All
