Standalone ECU important iacv gen2 note! WITH MEGASQUIRT
zen
do not use gen2 iacv with megasquirt..it has center tap to coils joined together internally..(atleast mine does) making it a 5 wire stepper..ms will not work with it..need to fit gen 1 iacv with seperate coils..
then all you do is cut out/not use the center tap..ie on mine the black/red wires on plug or according to 1996 ls400 wiring dia on here white wires.
Could you post some pictures of the different units? I have a 95 motor, which is like yours I believe (black/red wires to two centre posts).
I have just started my MS3 rewire and am hunting all info possible. Changing to CoPs as well.
