I don't know the iacv inside and out so here I go. I have a low idle. The only thing I haven't done is replace the idle air control valve and/ or the ecu to relieve the low idle issue... Here's the scenerio. Its a 94 sc400 (CA emissions) when first starting the engine cold the idle is around 750 rpms. Then as it slowly warms up the idle starts to curve downward like its supposed to. But it keeps getting lower and lower all the way down to the point where the car starts to shake.
Does this sound like the idle air control valve is working properly? I guess its working somewhat b/c the idle starts to lower as the car warms up. But it doesn't idle high enough when the engine is completely cold and once it warms up to normal operating temperature the idle drops too low.
I have cleaned the valve. So basically to sum up my question. Even though it idles down after the engine starts getting warm is it possible that the idle air control valve isn't working properly (as in something electronic)? As in opening far enough to let the correct amount of air pass by. Nothing seemed to be seized when I rotated the shaft inside the valve that moves in and out. There was no resistance when turning it by hand. Maybe something electrically is wrong with it and it doesn't allow the valve to open completely? Anyone know about these idle air control valves and exactly how they operate?
I know they receive the signal from the ecu to change the motor to adjust the idle and I know they get dirty.
Also what generates the tach speed? Is there a sensor that tells the ecu what rpm the engine is running at?
