...1uzfe gen 2 1995..with the SEALED iacv..ie cant strip it and clean it...
engine in old range rover..gearbox manual..
cold start up fine,idles down fine once hot..town driving all fine..tick over good...
but on a run of any sort,ie dont go onto idle often ,the tick over will drop to stall speed (once one stops,say at traffic lights..)..it will very slowly pull itself up, and then be fine in traffic but you have another run again and same stall at idle....
just about to go check for codes and that tps is set ok and working,ecu wired fine..(using a/c ecu input to control idle speed when switching on all the lights..(it has lots!))
odds on iacv? cant clean it and cost £££ here new...(so dont want to replace to find ok..)
