Hydo fan as dry sump pump?
EFIRover
Does anyone know if a hydraulic fan pump would be suitable for a dry sump? Im thinking of dry sumping my 1uz :006:
Nowhere near large enough.
Scavenge pump(s) need MINIMUM 2.5 x pressure pump capacity.
Pump also needs to be at bottom of block height.
RMS, what flow rates are we looking at in a 1uzfe ? That would be helpful when seeking for a proper oil pump, i wouldn't like to disassemble my pump only to measure it and calculate the flow :/
Did you ever heard of using electricity driven scavenge pumps ?
Thousand of sprint car engines beg to differ, They run them directly off the front of the camshaft on a pushrod v8 block. Though it is a good idea to run the pressure pump below the height of the oil tank, that was it is primed by gravity on startup.
have fun
Simon
Tomas,
We don't use the std oil pump so I really don't know. We us a Dailey Engineering 5 stage pump, 1 pressure, 4 scavenge, with centrifugal oil/air seperator.
Not sure I like the idea of an electric pump, fracture a wire or a faulty switch and you can lose an engine.
Simon,
I know a lot of scavenge pumps are mounted higher, but the higher you mount the pumps the more oil is held up in the sump, you have to have enough oil held in sump to cover the pickups and fill the extra length of lines.
It works OK but is not as efficient as it could be.
Dirt track cars also need to eliminate the possibilty of dirt breaking a drive belt.
