1 1200det New Member Jul 9, 2005 #1 Vehicle is a UZS131 Crown and the idle is just hunting from like 1000 - 1500 in perfect timing up and down. I have cleaned the ISC with carb cleaner and seems when i remove the pipe that connect the ISC to the intake pipe after the AFM the car idles fine ? Any ideas ?
B Blown SC New Member Jul 9, 2005 #2 Replace the 2 bearings in the ISC. They are small and easy to do..
1 1200det New Member Jul 9, 2005 #3 Ive just done as per the manual in regards to checking the ISC operation via hooking power to the isc and nothing is happening ? Blown-SC - Could that be the bearings ?
1 1200det New Member Jul 9, 2005 #4 I have the ISC open and can see the bottom bearing and a magnet ? How do these work ? Come apart from hear on in ? Blown SC said: Replace the 2 bearings in the ISC. They are small and easy to do.. Click to expand...
1 1200det New Member Jul 9, 2005 #5 Blown-SC your a legend , Yes the inside bearing was totally ceased up
