found it, idle motor is different to crown one, I am using crown ecu on majesta motor, idle motor is totally diff in design to crown one but plug is same, it worked ok in front cut, is now spitting out code 42 and check light stays on if you rev it, has a slight mis like a plug but clears after a few revs, but Im happy now, dam it sounds sweet
