jibby
Lowboy NZ - That is what I thought a peice of cake.... Well check this... First off you need to remove the radiator and fan assembly, hose lines etc..., no biggie, then you need to remove the serp belt and all that plastic crap around the engine bay...Way over kill on the plastic stuff by Lexus... anyway then the fun starts for me atleast, I go to remove the Hydraulic pump pulley to assess the removal nuts on the pump and the main pulley nut strips out on me... I even lubed the nut realising it has not been removed in 14 years. After it stripped I put the puller tool on it and pulled while turning the nut and nothing. I figured maybe these import engines have reverse threading on the pulley's and it stripped that way. I always use the old rule (righty tighty and lefty loosey) well I guess maybe it didn't apply to this job....Or it just stripped out anyway...
So now I need to grind off the bolt, save the pulley and thrash the hydraulic pump...Then tomarrow go find a replacement pump to gut at the junk yards. Getting the pump for cheap should not be a problem but grinding that nut off will require some work. Done for the day here are some boring progress pic's of the nut that refuses to come off.... This is not just an easy job, and I still need to remove the pump, plug the lines, mount and install the new fan yet, hook up the heat sensor, etc...trust me this job is not a piece of cake, doable but not a piece of cake....but so far I am having fun I guess and it is coming along...
I included a before engine picture and will post an after one as well. I better gain a few ponies off this swap after all this.....Late-
