How I installed EVO8 Brembo brake onto LS400
The EVO disc size is 320 mm. I think it the same size as Supra unit. I like the 355mm dise set up that retrodrive have but it was too expensive.
First I use paper cardboard to make template then send it to metal shop to have it made. Some washer was add to adjust the caliper.
Nice job! Can I ask what type of body kit you have and is it fibreglass or polyurethane??
hey whats up guys?
I wanted to know if i would be able to do this up grade to my 92 sc400. Im trying to keep cost down. And would the same type of adapter work for my car.?
Red Brembo is an eye catcher. That what I like about it. Both Supra and Brembo should give the similar performance.
I think that "brake pad" play big role in brakeing performance.
I like the idea of getting seals, pistons, even pads at the local Toyota dealer, + I like the OEM inspections that aftermarket stuff just doesn't get.
This is a nice swap, since the stuff can now be purchased through the Mitsubishi dealer, best of both worlds!
