This has been pressing for a while.... A few independant studies have shown that changing the catalytic converter to a highflowing catalytic converter in SC's does just about nothing for you.... I am now discussing and debating this same subject on the CL forums with others and need to hear from you guys about this....
My 1992 SC400 Lexus has been dealer maintained with 100,000 when I first changed out my stock cat..... I purchased a Magnaflow 2 into 1 highflowing catalytic converter...This is what I found, tested and discovered during the mod change:
1) Immediately after my stock cat was removed and still hot to the touch I put the new magnaflow cat next to it and shot compressed air threw both to test the difference in passing air flow.. The stock backened cat of 14 years was barely was able to pass the air out the back and the new Magnaflow allowed the air to pass like it wasn't even there....
2) This magnaflow cat. has a high flow built in Y design that replaces the first stock Y...I believe the flow is increased with both the cat and the built in Y...
I road tested before and after the install. I noticed power gains clearly and immediately to my suprise... Only the cat was changed out at that time and nothing else on my exhaust system...
Now how does you explain this? I truley believe there are nice gains to be made and I thinkI proved it, but so many think otherwise...Why do the experts say different? I don't think my stock cat. would be any different or worse off then any other 100,000 older lex car... Am I missing something here? Here is a pic....
Anyone?
Anyone?
