High HC at Idle???
UZ4runner
My 1uzfe out of a 93 LS400 failed emmissions at idle (590rpm). The max allowable Hydrocarbons is 220 PPM and 1098 was read. CO was measured a 0.54% (1.2% max allowable) The high speed (2500rpm) test passed at 173 PPM HC and 0.75%. Any Ideas what could be causing this?:confused:
Info:
1. I did find a loose spark plug after the failed test. There was obvious signs of leakage aroung the plug.
2. The EGR is blocked off.
3. I have been running 87 octane gas.
Any ideas? Thanks!
Andrew
High CH figures typically indicate incomplete combustion and maybe some oil in combustion chamber, the latter is likely due to never replaced stem seals.
