ok its cold, but only 0 c..
on cold start up it will rev at 1800-2000rpm..it will drop to 650 when at normal operating temp..
what could cause this? i assume this is not normal..
if it was idle control sticking open then it would have a high tickover when hot surley (cleaned it anyway)
same with an airleak too..(can't find one with smoke)
its not pulling any error codes...(other than where the F%%k are my secondary o2 sensors?it ain't got none)
thought about restricting the air feed pipe to idle control to keep high idle down, but really want to keep hot idle up (though in theroy restriction should not bother hot idle as using less air anyway..)but this is a bodge really..
