UZZ30-Québec
Man, i searched and searched for nothing. It's so SIMPLE!!!!!!
To activate the stock amp in a 1991 LS400 *nakamichi system*, simply put your remote wire with the Pink/blue wire inside the car, that's it, the amp doesn't get current from the radio wiring system.
The only thing i need to figure is to give it the sound signal, when i send High input into the pink wire in the car (wether it's a + or - from the radio i get the same result) I have bass but it's very low and the amp keeps triggering the breaker. Wether i put a + or - to t he blue wire, i loose the sound from my aftermarket radio. (short circuit)
It's very bizzare because i have a direct ground on the blue wire, it's supposed to be WP- and i don't really understand.
well, wiring is easy, on the amp, white = power, green = amp output to woofer, red/wht = unused (mute).
I'll try to split a RCA cable and feed it with low-level but i'm afraid to blow my low-level output from my radio... I'll get back on this, it's pretty useful for someone who wants to change the receiver but keep the sub working.
